400 -sarjan vikakoodit
  • 0 Vastauksia
  • 40523 Lukukerrat
Poissa Ristus
    • Kotisivut
« : 28.10.2010, 11:08:31 »
koodinlukija
Linkki aiheesta englanniksi
ja vähän koodejakin....
Socket 1 — alarm and remote locking system
Code:
1-1-1    No error code set
1-1-3    Transmitter to receiver: weak signal
1-1-4    Control Module (CM) faulty
2-1-1    Relay contacts, fuse or ground terminal (locking)
2-1-2    Relay contacts, fuse or ground terminal (unlocking)
2-2-1    Fuse or ground terminal (locking)
2-2-2    Fuse or ground terminal (unlocking)
2-2-3    Codes 2-2-1 and 2-2-2 combined
3-1-2    Siren: internal fault
3-2-1    Siren: power supply
4-1-2    Ultrasonic system: internal fault
4-1-3    Ultrasonic system: one or more sensors faulty
5-1-1    Key switch ground on (> 10 seconds)
5-1-2    Key switch ground off (> 10 seconds)
5-1-3    Locking door with ignition on
5-1-4    Unlocking door with ignition on
5-2-1    Central locking system switch (> 10 seconds locked)
5-2-2    Ultrasonic switch (> 20 seconds locked)
5-3-1    Interior lights, shorting to earth
Socket 2 — fuel system
Code:
1-1-2    Malfunction in Electronic Control Module
1-1-3    Open circuit in injector wiring
1-2-1    Air pressure sensor: no signal correspondence
1-2-2    Air temperature sensor: no signal or signal faulty
1-2-3    Coolant temperature sensor: no signal or signal faulty
1-3-2    Incorrect battery voltage
1-4-3    Knock sensor: no signal or signal faulty
2-1-2    Oxygen sensor: no signal or signal faulty
2-1-4    Flywheel sensor: signal faulty
2-2-2    System relay coil: no voltage
2-2-3    Idle speed regulating valve: no signal or signal faulty
2-3-1    Adaptive Lambda closed loop control system lean or rich in part–load range
2-3-2    Adaptive Lambda closed loop control system lean or rich at idling speed
2-4-4    Knock sensor: no signal or signal faulty
3-1-1    Speedometer signal: no signal correspondence
3-1-3    Charcoal absorption canister valve: signal faulty
3-4-2    A/C relay signal: signal faulty
3-4-3    Main relay coil: no voltage
4-1-1    Throttle valve sensor: signal faulty
Socket 3 — ABS
Code:    (40 km/h = 25 mph)
1-2-1    Left side front wheel sensor: faulty signal at speed less than 40 km/h
1-2-2    Right side front wheel sensor: faulty signal at speed less than 40 km/h
1-2-3    Left side rear wheel sensor: faulty signal at speed less than 40 km/h
1-2-4    Right side rear wheel sensor: faulty signal at speed less than 40 km/h
1-2-5    Signal faulty from at least one sensor for a long period
1-3-5    Control Module (CM) faulty
1-4-1    Faulty pedal sensor: shorted to ground or supply
1-4-2    Faulty stop (brake) lamp switch: open circuit
1-4-3    Control Module (CM) faulty
1-4-4    Brake discs overheated
1-5-1    Left side front wheel sensor: open circuit or short-circuit to battery voltage
1-5-2    Right side front wheel sensor: open circuit or short-circuit to battery voltage
1-5-5    Rear axle sensor: open curcuit or short-circuit to battery voltage
2-1-1    Left side front wheel sensor: no signal or moving off
2-1-2    Right side front wheel sensor: no signal or moving off
2-1-3    Left side rear wheel sensor: no signal or moving off
2-1-4    Right side rear wheel sensor: no signal or moving off
2-1-5    Valve relay: open circuit or short-circuit
2-2-1    Left side front wheel sensor: ABS operation signal missing
2-2-2    Right side front wheel sensor: ABS operation signal missing
2-2-3    Left side rear wheel sensor: ABS operation signal missing
2-2-4    Right side rear wheel sensor: ABS operation signal missing
2-3-1    Left side front wheel sensor: signal missing
2-3-2    Right side front wheel sensor: signal missing
2-3-5    Rear axle sensor: signal missing
3-1-1    Left side front wheel sensor: open circuit or short-circuit
3-1-2    Right side front wheel sensor: open circuit or short-circuit
3-1-3    Left side rear wheel sensor: open circuit or short-circuit
3-1-4    Right side rear wheel sensor: open circuit or short-circuit
3-2-1    Left side front wheel sensor: irregular interference at speeds over 40 km/h
3-2-2    Right side front wheel sensor: irregular interference at speeds over 40 km/h
3-2-3    Left side rear wheel sensor: irregular interference at speeds over 40 km/h
3-2-4    Right side rear wheel sensor: irregular interference at speeds over 40 km/h
4-1-1    Left side front wheel inlet valve: open circuit or short-circuit
4-1-2    Left front return valve: open circuit or short-circuit
4-1-3    Right side front wheel inlet valve: open circuit or short-circuit
4-1-4    Right front return valve: open circuit or short-circuit
4-1-5    Rear valve: open circuit or short-circuit
4-2-1    Rear wheel circuit inlet valve: open circuit or short-circuit
4-2-2    Rear wheel circuit return valve: open circuit or short-circuit
4-2-3    Traction Control System (TRACS) valve: open circuit or short-circuit
4-2-4    Pressure switch for TRACS: faulty or short-circuit
4-4-1    Control Module (CM) faulty
4-4-2    Pump pressure low
4-4-3    Pump motor/relay: electrical or mechanical fault
4-4-4    No power supply to valves in hydraulic unit
Socket 6 — cruise control
1-1-1    No error code set; speed was higher than 40 km/h
1-1-2    Vehicle Speed Sensor: abnormal signal received
1-2-2    Vehicle speed: 40 km/h not exceeded or no signal
2-1-1    Fault in supply voltage or Control Module
2-1-2    Circuit to vacuum pump or regulator: signal faulty
Important:  cruise control diagnostics must be done immediately after the test drive.  Do not turn the engine off!  Codes will not be saved in memory if you do.
Socket 7 — SRS (airbag)
Code:
1-1-2    Internal fault in the sensor unit
1-2-7    SRS warning lamp: open circuit or short-circuit
2-1-1    Steering wheel module: short-circuit in wiring
2-1-2    Steering wheel module: open circuit in wiring
2-1-3    Steering wheel module: short-circuit to the ground
2-1-4    Steering wheel module: short-circuit to +12V
2-2-1    Passenger module: short-circuit in wiring
2-2-2    Passenger module: open circuit in wiring
2-2-3    Passenger module: short-circuit to the ground
2-2-4    Passenger module: short-circuit to +12V
2-3-1    Left seat belt tensioner: short-circuit in wiring
2-3-2    Left seat belt tensioner: open circuit in wiring
2-3-3    Left seat belt tensioner: short-circuit to the ground
2-3-4    Left seat belt tensioner: short-circuit to +12V
2-4-1    Right seat belt tensioner: short-circuit in wiring
2-4-2    Right seat belt tensioner: open circuit in wiring
2-4-3    Right seat belt tensioner: short-circuit to the ground
2-4-4    Right seat belt tensioner: short-circuit to +12V
(no code)    SRS warning lamp in the instrument panel does not light
(no code)    Fault in diagnostic output
YouTube
