Kierrätyskeskus => Racingosat => Myydään Racingosat => Aiheen aloitti: lollloomD - 11.06.2016, 17:05:21
Piston-conrod kit with arp bolts,L152, 96,28bore good condition SPM SOLD!
(http://s33.postimg.org/9irvto4wr/WP_20160610_001.jpg) (http://postimg.org/image/9irvto4wr/)
Cylinder head bolts 12:9 spm SOLD!
Scandix high volume oil pump (melling) SOLD!
(http://s33.postimg.org/j0i16e7dn/WP_20160610_005.jpg) (http://postimg.org/image/j0i16e7dn/)
Steel cranshaft sprocket SOLD!
(https://s31.postimg.org/7ln6qze5j/WP_20160618_008.jpg) (https://postimg.org/image/7ln6qze5j/)
Custom crank vent SOLD!
(http://s33.postimg.org/k16sf5wwr/WP_20160610_003.jpg) (http://postimg.org/image/k16sf5wwr/)
(http://s33.postimg.org/6fxmx2nkr/WP_20160610_010.jpg) (http://postimg.org/image/6fxmx2nkr/)
Stock crank, polished, measured, super oiling SOLD!
(http://s33.postimg.org/tjcyyg3q3/WP_20160610_006.jpg) (http://postimg.org/image/tjcyyg3q3/)
Oil squirters from turbo engine 50€
(http://s33.postimg.org/b0wq20q1n/WP_20160610_008.jpg) (http://postimg.org/image/b0wq20q1n/)
531 head, ported 220cfm, kyrk motorsports 46/38 stainless steel valves, double valve springs, alu retainers, KY1214cam 114grader nockvinkel 12,2mm lyft 287dur vid körspel, Populär profil för lite häftigare turbo +600HK, SPM camshaft sprocket SOLD!
Custom intake 5,5l plenum with 2,5 inch throttlebody, bosch TPS, trumpets inside, 250mm long runners, custom fuel rail with regulator, uses original volvo gas pedal connection, brake vac under plenum. SOLD!
1200cc high imp bosch motorsport injectors SOLD!
(https://s31.postimg.org/ih83f6ys7/WP_20160618_001.jpg) (https://postimg.org/image/ih83f6ys7/)
(https://s31.postimg.org/uaqmeylpj/WP_20160618_002.jpg) (https://postimg.org/image/uaqmeylpj/)
(https://s31.postimg.org/vjmvj6ro7/WP_20160618_007.jpg) (https://postimg.org/image/vjmvj6ro7/)
(http://s33.postimg.org/py4dbcue3/WP_20160610_027.jpg) (http://postimg.org/image/py4dbcue3/)
(http://s33.postimg.org/ex01eundn/WP_20160610_024.jpg) (http://postimg.org/image/ex01eundn/)
(http://s33.postimg.org/h9ma11l23/WP_20160610_025.jpg) (http://postimg.org/image/h9ma11l23/)
(http://s33.postimg.org/8fwr62cwr/engine.jpg) (http://postimg.org/image/8fwr62cwr/)
360rwkw 590nm wheel / 580hp 707nm engine
(http://s33.postimg.org/i8el326sb/WP_20160602_002.jpg) (http://postimg.org/image/i8el326sb/)
Im open to all offers, can be transported to finland.
All parts in good condition, straight from running engine.
Thanks
Cylinder head and crank vent sold to user 2fast4you :)
Intake manifold, bosch injectors, steel sprocket sold to user Tepi :)
Piston-conrod kit, oilpump, headbolts, crank sold to user PKM
Everything sold exept oil squirters. Love to make deals in this forum. Thanks 8)
do you have still those oil squirters?
Do you still Have oil squirters?
