Kierrätyskeskus => Takavetoisten ilmoitukset => Myydään varaosat => Aiheen aloitti: tuplat - 20.04.2020, 23:00:29
VOLVO VINOKONEESEEN 40 MM. TUPLAKAASAREILLE TEHTY IMUSARJA.
IMUSARJA ON ITSE TEHTY KAHDESTA ERI VINOKONEEN ZENITH / STROMBERG KAASARIN IMUSARJASTA. IMUPUOLELLE ON TEHTY LAIPAT JOTKA ON HITSATTU ALKUPERÄISIIN ZENITH / STROMBERG KAASARIN IMUKAULOIHIN. LAIPAT ON TASATTU JA OVAT LINJASSA.
AINUT PIKKU VIBA ON, ETTÄ KAASARIT JÄÄVÄT JONKIN VERRAN PYSTYYN, ELI ILMANOTTOPUOLI / ILMASUPPILOPUOLI JÄÄ YLEMMÄKSI KUIN IMUPUOLI. ELI KAASARIT JÄÄVÄT JONKINVERRAN KENOLLEEN.
IMUSARJA OLI KÄYTÖSSÄ SOLEX 40 MM. TUPLILLA JA VAIKKA KAASARIT OLIVAT JONKIN VERRAN KENOLLAAN, NIIN EI TUNTUNUT JUURI MENOA HAITTAAVAN. IMUSARJA OLI KÄYTÖSSÄ, EIKÄ VUOTOJA HITSAUSKOHDISSA ILMENNYT.
KUVISTA NÄKEE KUINKA KAASAREIDEN PUOLEN LAIPPOJA ON TYÖSTETTY KAASAREIDEN VAATERIIN SAAMISEKSI.. LAIPOISSA ON VIELÄ JONKIN VERRAN VARAA OTTAA LISÄÄ AINESTA POIS KAASAREIDEN VAATERIIN SAAMISEKSI.
ONHAN SE HIEMAN RAAKILEEN OLOINEN, MUTTA ASIANSA AJOI.
Hinta 30,00 Eur. + postit 7,90 Eur.
(https://i.ibb.co/4g20Q9N/IMG-3311.jpg) (https://ibb.co/4g20Q9N)
(https://i.ibb.co/bN9PdH2/IMG-3313.jpg) (https://ibb.co/bN9PdH2)
(https://i.ibb.co/J7mbfc8/IMG-3310.jpg) (https://ibb.co/J7mbfc8)
(https://i.ibb.co/GkNPMdG/IMG-3315.jpg) (https://ibb.co/GkNPMdG)
VOLVO 700 SARJALAISEN UMPIOT.
UMPIOT OVAT MUUTEN HYVÄKUNTOISET, MUTTA LASIPINNAT OVAT SUMENTUNEET AJAN SAATOSSA. KAIPAAVAT HIEMAN KIILLOTUSTA.
HINTA 15,00 Eur. + POSTIT 7,90 Eur.
(https://i.ibb.co/jGwVMJr/IMG-3307.jpg) (https://ibb.co/jGwVMJr)
(https://i.ibb.co/N2FL8yx/IMG-3312.jpg) (https://ibb.co/N2FL8yx)
(https://i.ibb.co/SmmyxtQ/IMG-3308.jpg) (https://ibb.co/SmmyxtQ)
KOLMIKIILA HIHNAPYÖRÄ KAMPIAKSELIN PÄÄHÄN.
HINTA 15 Eur. + POSTIT 7,90 Eur.
B 23 VINOKONEEN KIERTOKANGET.
YHDESSÄ KIEROKANGESSA ON 1 PINNAPULTTI POIKKI. MUUTEN KANGET OVAT HVÄKUNTOISET.
Hinta 20 Eur. + POSTIT 7,90 Eur.
B 21 VINOKONEEN KIERTOKANGET + MÄNNÄT.
KIERTOKANGET ON HYVÄT, MÄNNÄT YHTÄ LUKUUN OTTAMTTA VIELÄ KÄYTTÖKUNTOISET. YHDESSÄ MÄNNÄSSÄ ON VAURIOITA SULAMISEN TAKIA. EN VIITSI OTTAA MÄNTÄÄ KANGESTA POIS, JOTEN SEN SAA KAUPAN TEKIJÄISIKSI.
HINTA 30,00 Eur. + POSTIT 7,90 Eur.
REDLINE : PESTÄVÄT PUHDISTINSUKAT JOTKA VEDETÄÄN IMUTORVIEN PÄÄLLE. 4KPL.
KAHDESSA SUKASSA ON IMUTORVIEN KOHDALLA PIENET VEKIT LÄPI ASTI. HOITUU PARILLA TIKILLÄ. AIKA JA SUKKIEN PESU AINA VÄLILLÄ ON HAALISTANUT SUKKIEN ALKUPERÄISTÄ KIRKASTA PUNAISTA VÄRIÄ, MUTTA MUUTEN SUKAT JA NIIDEN SISÄLLÄ OLEVAT JOUSET OVAT HYVÄ KUNTOISIA.
Tuossa linkki kuvaan sukista. kuva on freetechnicsin sivuilta. Eli, kuvan sukat ei ole myynnissä olevat!!
Linkki - http://freetechnics.fi/polttoainepuoli/ilmanpuhdistimet.html
MUKAAN TULEE PARI VAJAATA MOTULIN AIR FILTER ÖLJYPULLOA.
HINTA : 65 Eur. + POSTIT 5,90 Eur.
B19 / B21 / B23 LATURI. HINTA 45 Eur. + Postit 7,90 Eur.
(https://i.ibb.co/Wz9S9Rs/IMG-3339.jpg) (https://ibb.co/Wz9S9Rs)
(https://i.ibb.co/ZKMsVj4/IMG-3340.jpg) (https://ibb.co/ZKMsVj4)
LISÄMITTAREITA. HINTA 35,00 Eur. + Postit 5,90 Eur.
SMOKE : ILMA / POLTTOAINESEOSMITTARI.
ÖLJYNPAINEMITTARI + ANTURI. ANTURISSA ON KIINNNI LETKU. VOVON VINOKONEESSA ON ÖLJYNSUODATIN NIIN LÄHELLÄ ÖLJYKELLON PAIKKAA, ETTÄ ANTURI EI SOVI PAIKOILLEEN, JOTEN TARVITSI TEHDÄ KYSEISENLAINEN ''SOVELLUS''.
VOLTTIMITTARI
KIERROSLUKUMITTARI
VEDENLÄMPÖMITTARI + ANTURI. ANTURI ON KIINNI VOLVO 200 SARJALAISEN YLÄVESILETKUSSA.
MUKAAN TULEE PURISTUSPIHDIT JA ABIKOLIITTIMIÄ.
(https://i.ibb.co/ngpVwDn/IMG-3382.jpg) (https://ibb.co/ngpVwDn)
(https://i.ibb.co/hCLfzJB/IMG-3374.jpg) (https://ibb.co/hCLfzJB)
(https://i.ibb.co/wzm16pF/IMG-3375.jpg) (https://ibb.co/wzm16pF)
(https://i.ibb.co/QQs561G/IMG-3376.jpg) (https://ibb.co/QQs561G)
(https://i.ibb.co/k6N9NHv/IMG-3378.jpg) (https://ibb.co/k6N9NHv)
(https://i.ibb.co/DwZzmVK/IMG-3380.jpg) (https://ibb.co/DwZzmVK)
(https://i.ibb.co/0Q59vyP/IMG-3387.jpg) (https://ibb.co/0Q59vyP)
(https://i.ibb.co/MP2msZr/IMG-3383.jpg) (https://ibb.co/MP2msZr)
200 SARJALAISEN ETUJARRUSATULAT 2 kpl. HINTA 10,00 Eur. + Postit 7,90 Eur.
TOISESSA ON VAIN 1 MÄNTÄ JA TOISESSA ON KAIKKI 4 MÄNTÄÄ + IHAN KÄYTTÖKELPOISET JARRUPALAT.
(https://i.ibb.co/RTBGh9q/IMG-3321.jpg) (https://ibb.co/RTBGh9q)
(https://i.ibb.co/rsSLjMN/IMG-3322.jpg) (https://ibb.co/rsSLjMN)
VINOKONEEN SUORA VAUHTIPYÖRÄ. HINTA 15,00 Eur. + Postit 7,90 Eur.
(https://i.ibb.co/30XYMLz/IMG-3364.jpg) (https://ibb.co/30XYMLz)
VESIPUMPUN HIHNAPYÖRÄ. HINTA 5,00 + POSTIT 5,90 EUR.
(https://i.ibb.co/GRTK2M6/IMG-3565.jpg) (https://ibb.co/GRTK2M6)
DELLORTO DHLA 40 TUPLIEN SISÄKURKKUT 4 KPL. HINTA 35 EUR. + POSTIT 5,90 EUR.
KURKUT OVAT KOOLTAAN 32 MM. - YHDEN KURKUN SISÄPINNASSA ON YHDELLÄ KOHTAA ORKOSIA. OLI NIIN PIRUN TIUKASTI KIINNI KAASARISSA, ETTÄ JOUTUI RUUVARIN JA VASARAN KANSSA IRROTTAMAAN. EIVÄT VAIKUTA ILMANVIRTAUKSEEN TAI HUIPPUNOPEUTEEN 8) 8)
(https://i.ibb.co/Y8Ct1sd/IMG-3577.jpg) (https://ibb.co/Y8Ct1sd)
(https://i.ibb.co/KFkL4t6/IMG-3578.jpg) (https://ibb.co/KFkL4t6)
VINOKONEEN VENTTIILINKOPPA. HINTA 10 EUR- + POSTIT 5,90 EUR.
(https://i.ibb.co/tBfVhGG/IMG-3575.jpg) (https://ibb.co/tBfVhGG)
