B230 Hot side bolt on kit, HX40super
  • 4033 Lukukerrat
Poissa lollloomD
« : 11.06.2016, 13:40:52 »
B230 bolt on hot side kit with everything you need: 38mm outer diameter tig welded, ceramic coated, divided exhaust manifold with pressure mesauring spot and egt sensor mount(can be welded shut), In good condition HX40super with #16 hot side(coated), 44mm tial wastegate with two screamer pipes(under car and out from behind front wheel) and one to the exhaust. 3,5inch stainless wrapped downpipe with lambda hole and possible pressure mesauring spot(all connections vband)+out of the car side 3inch straight pipe with mounts(for racing purpose), 4 inch almost unused AEM big air filter, oil feed and return lines, modified new water pump
Everything in great condition from my own car.
2-2.5bar at ~4000rpm and 2,5bar produced 580hp 707nm engine.
Price: 1300€
Can be transported to finland as always.
Open to offers if someone is really interested :)
Thanks
« Viimeksi muokattu: 11.09.2016, 10:31:04 kirjoittanut lollloomD »
Poissa lollloomD
Vs: B230 Hot side bolt on kit, HX40super
« Vastaus #1 : 28.06.2016, 17:41:47 »
1200€
« Viimeksi muokattu: 08.07.2016, 18:35:10 kirjoittanut lollloomD »
Poissa lollloomD
« Vastaus #2 : 19.07.2016, 21:30:55 »
UP!  8)
Poissa lollloomD
« Vastaus #3 : 03.08.2016, 21:45:48 »
1150€
Poissa lollloomD
« Vastaus #4 : 22.08.2016, 15:31:38 »
1100€
Poissa lollloomD
« Vastaus #5 : 06.09.2016, 08:35:21 »
Good hotside kit for good price!
Poissa lollloomD
« Vastaus #6 : 13.09.2016, 20:59:39 »
Sold to user: 740sankari  :)  Thanks guys 8)
