Volvo S60 2002 fuel pump relay
  • 19 Vastauksia
  • 8218 Lukukerrat
Poissa Volverin
« : 21.08.2017, 18:46:42 »
Hi, does anybody knows where the fuel pump relay located in the Volvo S60 2002 2.4 petrol? Thanks in advance
Poissa Ristus
    • Kotisivut
Vs: Volvo S60 2002 fuel pump relay
« Vastaus #1 : 21.08.2017, 18:52:41 »
YouTube
Poissa Volverin
« Vastaus #2 : 21.08.2017, 20:20:13 »
Unfortunately on the driver side there is no relays
Poissa Ristus
    • Kotisivut
« Vastaus #3 : 21.08.2017, 20:30:23 »
then your car is 2001 model and relay is under the bonnet, there is that fuse/relay box in engine bay relay marked 103 is fuel pump
https://www.matthewsvolvosite.com/fxi-volvo-fuel-relay.html
YouTube
Poissa Volverin
« Vastaus #4 : 21.08.2017, 20:38:40 »
It is 2002 model I have been to bilia bought the relay and they could not figure out where it goes. Today run diagnostics and give some error code regarding to fuel pump relay.
Poissa Ristus
    • Kotisivut
« Vastaus #5 : 22.08.2017, 07:14:40 »
There is 3 possible locations for relay left side on trunk and those two already mentioned as you have the relay compare it to those that are in trunk.
YouTube
Poissa Volverin
« Vastaus #6 : 22.08.2017, 07:43:27 »
in the front fuse box there are 4 same relays same they sold me. According to the instructions from inside of the fuse box relay, none of those is the fuel pump relay. In the back of the trunk there is more relays, but no sign on it, and in the service book wont mention about relays at all, only fuses. Thanks again for the help, really appreciate it. Going to Spain in a week and I really want that the car wont die on my on the way :)
Poissa Ristus
    • Kotisivut
« Vastaus #7 : 22.08.2017, 09:20:19 »
That fuel pump relays location looks to be one big secret. You should ask directly from some volvo mechanic they usually are helpful with these older cars.
YouTube
Poissa Volverin
« Vastaus #8 : 22.08.2017, 09:22:38 »
I did ask the guy at Bilia from where i bought the relay, he didnt know it either, he said that I should look at wiring diagram, and figure out where it goes.
Poissa Ristus
    • Kotisivut
« Vastaus #9 : 22.08.2017, 09:34:13 »
that guy must be part seller they don't know much. In garage side are those who knows. I have one idea that I need to check
YouTube
Poissa Ristus
    • Kotisivut
« Vastaus #10 : 22.08.2017, 10:02:35 »
That is you fuel pump relay i just cant figure out that what position that picture is taken but that is correct relay, checked from vida, just don't have wiring diagrams now.
here is wiring diagram http://volvowiringdiagrams.com/volvo/S60%20Wiring%20Diagrams/TP3960202%20S60%20S80%202002%20Wiring%20Diagrams.pdf
« Viimeksi muokattu: 22.08.2017, 10:09:18 kirjoittanut Ristus »
YouTube
Poissa Volverin
« Vastaus #11 : 22.08.2017, 10:25:29 »
the relay what they sold me its a bit smaller than that, its same like fmi1 and fmi2
Poissa Ristus
    • Kotisivut
« Vastaus #12 : 22.08.2017, 11:02:58 »
You got wrong part then. Show that picture them and ask double check from they system.
YouTube
Poissa Volverin
« Vastaus #13 : 22.08.2017, 13:04:04 »
There are 3 same relays in there, I did switch the places but no change
Poissa Volverin
« Vastaus #14 : 22.08.2017, 15:13:41 »
Just check it now, there’s nothing in fst2, according to the information in the back of the fuse cover it says bi-fuel
