MYYTY: Volvo 960 mk2 -96 (Virossa)
  • 0 Vastauksia
  • 7322 Lukukerrat
Poissa wckd
« : 06.06.2018, 14:06:14 »
Hi,
As I've recently become a thrilled owner of a '04 V70R (AWD, BSR, Manual, Atacama) I'm selling my beloved 1996 Volvo 960 to regain some parking space :(
Fault list:
  • some rust in wheel arches although not too noticeable at a glance
  • slight oli seepage from valve cover bolt threads / likely oil filter gasket (not enough to leave a mark when parked)
  • reverse lights don't work due to slightly misaligned gear position sensor (shifts etc. are fine)
  • right fender blinker needs a new bulb
  • small bubbly patch on the corner of the bonnet (weird since it's aluminum  ???)
  • one rear door won't release from outside (handle linkage need adjusting)
  • rear coilovers need some fine-tuning - spring gets momentarily loose on full droop
  • slight exhaust leak from between headers / cat pipe when cold
  • there's probably more which I can't remember right now
The car:
  • B6304GS (w/o cat)
  • AW30-43
  • M4.4
  • Nautic blue pearl (417-12)
Equipment:
  • Black leather interior
  • electric moonroof
  • electric driver seat with memory
  • cruise control
  • front seat heaters
  • adjustable interval wipers (VW retrofit)
  • "komfortblinker" (VW retrofit)
  • GE Motorsports front shocks
  • L-M-R front 940 lowering springs
  • polyurethane front suspension bushings (swaybar, control arms)
  • GAZ rear coilovers with 8" 350lbs + 4" helper springs & nivo leaf
  • 18" RVS Spyder wheels with ok tires (225/45/18)
  • Pioneer audio (DEH-9300SD + speakers + amp)
  • Recently replaced battery (Exide AGM)
  • Previous owner (before me) - Latvian government
  • almost another car's worth of interior / electronic bits gratis (if interested)
Interior photos on request.
Price: 2500€
Sorry for the english but I'm even worse with finnish :P
Thanks,
Jaan
YV / SMS 37258200253
« Viimeksi muokattu: 01.08.2018, 11:23:36 kirjoittanut wckd »
