M: B6284T engine project set / parts
  • 1 Vastauksia
  • 4611 Lukukerrat
Poissa wckd
« : 11.06.2018, 14:53:12 »
Selling my T6 RWD engine project bits, ideally as a set but might consider offers for individual items...
  • 1999 B6284T block (w/ oil squirters) + head (thoroughly cleaned, head milled, CNC valve job done, new valve stem seals)
  • B6304 RWD oil pan
  • H-beam rods with ARP rod bolts
  • T6 stock pistons
  • New STD piston rings
  • ARP Head bolts + lube
  • ARP Crank bolts + lube
  • Glyco sputter rod bearings
  • Glyco main bearings
  • Some gaskets (HG, oil squirter cover, VVT)
  • Single mass flywheel from 850
  • Oil thermostat for external cooler outlet modified to AN10
  • 2 x AN12 cam cover vent outlets
+ Some pulleys, sensors, solenoids, valves
+ B6304 intake octopus intake
+ B6284T stock exhaust manifolds & turbos
+ 2 sets of b6304 cams
+ Redline assembly lube
+ Pack of Plastigauge A
Price: €2000
Location: Tallinn, Viro (might be able to deliver to Helsinki if bought as a set).
YV
« Viimeksi muokattu: 18.06.2018, 23:07:47 kirjoittanut wckd »
Poissa WineX
Vs: M: B6284T engine project set / parts
« Vastaus #1 : 06.02.2019, 23:57:04 »
Löytyykö tämä vielä?
