Tekniikka, Viritys, Veteraanit ja Projektit => Projektipäiväkirjat => Aiheen aloitti: volovo mies - 25.06.2014, 21:22:14
tuli tuossa ostettua käyttis mutta se joutui pajalle puolentoista kuukauden ajon jälkeen.
auto on vm-97 glassic elikkäs aikalain kaikki lisävarusteet mitä on saanut näihin.
tekniikka=B230FT+M90+G80
pajalle joutui ku perään ajettiin
kuvat kertoo enemmän...
(http://i1051.photobucket.com/albums/s422/volovomies/10426483_10204120430116969_1709569731_o_zps1fc1414d.jpg) (http://s1051.photobucket.com/user/volovomies/media/10426483_10204120430116969_1709569731_o_zps1fc1414d.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/10429754_10204120430316974_589388819_o_zpsd4b97557.jpg) (http://s1051.photobucket.com/user/volovomies/media/10429754_10204120430316974_589388819_o_zpsd4b97557.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/10449331_10204120429276948_710186658_o1_zps040e996c.jpg) (http://s1051.photobucket.com/user/volovomies/media/10449331_10204120429276948_710186658_o1_zps040e996c.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/10457296_10204120430596981_302679224_o_zpsea17828d.jpg) (http://s1051.photobucket.com/user/volovomies/media/10457296_10204120430596981_302679224_o_zpsea17828d.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/10457344_10204120430556980_1534130595_o_zps56a3dd37.jpg) (http://s1051.photobucket.com/user/volovomies/media/10457344_10204120430556980_1534130595_o_zps56a3dd37.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007515_zpse7ef8967.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007515_zpse7ef8967.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007516_zps7c4f88e0.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007516_zps7c4f88e0.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007518_zpsedd246a6.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007518_zpsedd246a6.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007523_zps7ea052fc.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007523_zps7ea052fc.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007524_zpsf0b6114c.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007524_zpsf0b6114c.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007525_zps65b8031f.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007525_zps65b8031f.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007526_zps5d34d76d.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007526_zps5d34d76d.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007527_zps752d5f22.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007527_zps752d5f22.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007528_zps9c553f90.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007528_zps9c553f90.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007529_zps38e4004a.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007529_zps38e4004a.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/hitsatut%20jutut/S__0BD110011_zpsc00b16c9.jpg) (http://s1051.photobucket.com/user/volovomies/media/hitsatut%20jutut/S__0BD110011_zpsc00b16c9.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/hitsatut%20jutut/Kuva00701_zps884c9f84.jpg) (http://s1051.photobucket.com/user/volovomies/media/hitsatut%20jutut/Kuva00701_zps884c9f84.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/13012007520_zps4de5b083.jpg) (http://s1051.photobucket.com/user/volovomies/media/13012007520_zps4de5b083.jpg.html)
Onpas kärry käynyt lähellä. Se on melkein jopa osunut! :D
Tarkoituksena laittaa takaisin ajoon? ;)
Taisi kärry pelastaa auton paalaukselta? Meinaan sopivan ylös suuntautunut suurin voima tällistä.
Tuliko eteen puskurin lisäksi muuta vauriota? Taakse tuli senkin edestä että toivotaan sen korjaamisella selviävän :D
paremmin ois säilynyt jos ois puskuriin osunut tuo kärry. ois menny puskuri ja ehkä luukku mutta nyt vääntyi c pilari.
ei raaski paalata ku on kumminki uusimpia 945 volvoja hyvällä tekniikalla joten koitetaan korjata.
maski hieman heikossa hapessa ja akku tärähti käyttökelvottomaksi.
iltoja.
kävin illan aikana pajiottaan kuskin takakyljen suoremmaksi.
aika kypsä homma oli pajottaa ku tankintäyttöputki oli pahimmoilleen edessä.
peräkontin lukkopellin painelin koritunkilla mielestäni oikeaan asentoon. samalla oikesi peräkontin pohjanpalkit. varsinaiset runkopalkit ei ole vääntynyt.
kiitos Ruuskasen Fix suuntaan koritunkin lainasta -H-
jekku (koiranpentu) oli koko illan puutarha-apulaisena= naiset teki kukkapenkkejä hallille ja istutti kukkia ja pensaita nii jekku auttoi ja perässä kaiveli niitä pois ja teki viereen uusia kuoppia. ei ilmeisesti kukkien paikat miellyttänyt S*
osia ois hyllyssä ja ajatusleikkinä konehuoneeseen päivityspaketti mutta nuo päästö pelleilyt rajaa mahdollisuuksia.
toisaalta kun ei tieliikenteessä saa tehojakaan juuri minkäänvertaa nii sama olla tunnissa paikalleen bolt on paketti ja kokeilu hommiin varaa tunnin pari enemmän aikaa.
hyllystä löytyy pari pikku mitsua oliko 14 vai 15 kokoa. purku 940glt 16valve kansi, erillinen hukkis, pakosarjan tekoon käyriä, letkuja ja liittimiä, vahvempia veivejä jne...
8valve toteutukseen olis titaani venttiileitä ja kansia muutama...
ei säkki ku tekis mieli alkaa virittään tätäkin kotteroa.
tulipa viikonloppuna värkättyä tämän kans.
peräpää alkaa olemaan aika lähellä suoraa ja loput pakkelilla.
pahin paikka oli noin 6cm painunut kasaan.
Tästä näin aiemmin jossakin kuvia, ja puhuttiin kaverin kanssa että kohta tulee foorumille tästä topic... Myyntiosioon varaosiks.
Kiva että joku näitä pelastaa, tsemppiä! :D
uus takaluukku istui eilen paikalleen ja kylki sai kittiä lisää.
kuvia tulee kunhan löydän jostaki muistikortin adapterin.
ei ole enää jumalattoman kaukana oikeasta asennosta tuo peräpää. luukku istuu jo hyvin paikalleen.
taka pilarit on jo suorassa ja taka kyljet aikalain muodossa.
aikataulu on sillan että alastarolle kerkiää ajamaan.
puskurit on hommaamatta ja takaluukun sisusta. osia voi tarjota yksityis viesteinä.
taka oven maalaan kans ja siihen pitää tehä pikku korjailua. muuten on viimeistely hieronnat ja sitte maali päälle.
puskurit pitää hommata nii saa samalla maaliin nekin.
jospa huomenna sais korvaus hommiin päätöksen ja rahat tilille.
korjaus arvio oli 5500€ ja edullisin vastaava nettiautossa 3200€. koitan olla jämynä kertakorvaus menettelyssä koska kolaria aiemman vertaista tästä ei saa yksikään seppä.
Se on oikia homma! Ja vinkkisi saatto poikia onnistumisen! :hello:
Mitä nopeesti vilasin, niin kyllä kahella tonnilla saa alle 3sataatonnia ajettuja Classicceja?
Mutta toivottavasti onnaa vahinkotarkastajan kanssa, itsellä on ainoastaan kitkeriä kokemuksia niiden kanssa asioinnista..
Onse hyvä että joku näitä jaksaa laittaa nii eivät ihan heti oo kaikki paalissa.
Paaliin vaan ja uutta tilalle, sekä sitä paalaamista ennen voin tulla ostamaan liudan osia tuosta :D
Mutta lienevätkö vastaavia.
Hyvä että sekin sai vielä hyötyelämän :)
eipä ole vastaavia. http://www.nettiauto.com/volvo/940?id_car_type=4&id_fuel_type=1&id_gear_type=2&yfrom=1997
huomio tekniikka ja kilometrit sekä vuosimalli.
Mä epäilen että sedanit ja farkut menee siinä samassa, kun vertaillaan. ??? Mut joo, toivottavasti lykästää!
jos tarvitset farmarin niin sillon ostat sen etkä edullisempaa sedania koska et voi käyttää sitä omiin tarpeisiin.
ei vakuutusyhtiö voi vaikuttaa siihen millä mallilla ajat ja mikä sopii sinun käyttötarkoitukseen ja käyttömieltymyksiin.
kertakorvaus hinta saatiin kohilleen ja nyt on vara ostaa osia kunnostamiseen ja ehkä vähä pellin allekkin.
muok.
ostin tänään uuden puhelimen nii saa edes jonkisortin kuvia otettua ja laitettua näkysälle.
parit kuvat tähän väliin.
vähä pitää liinoilla vetää vielä nii saa kohalleen.
(http://i1051.photobucket.com/albums/s422/volovomies/20140717_133804_zpsb36a12ad.jpg) (http://s1051.photobucket.com/user/volovomies/media/20140717_133804_zpsb36a12ad.jpg.html)
takapilari ja kylki muodossaan.
(http://i1051.photobucket.com/albums/s422/volovomies/20140717_133836_zps05584816.jpg) (http://s1051.photobucket.com/user/volovomies/media/20140717_133836_zps05584816.jpg.html)
peräkontin lattia palkit vedetty suoraan
(http://i1051.photobucket.com/albums/s422/volovomies/20140717_133953_zps026239c0.jpg) (http://s1051.photobucket.com/user/volovomies/media/20140717_133953_zps026239c0.jpg.html)
(http://i1051.photobucket.com/albums/s422/volovomies/20140717_134004_zps9509a154.jpg) (http://s1051.photobucket.com/user/volovomies/media/20140717_134004_zps9509a154.jpg.html)
peräkontin lukkopelti painettu suoraan.
(http://i1051.photobucket.com/albums/s422/volovomies/20140717_134015_zpsbd6d84fa.jpg) (http://s1051.photobucket.com/user/volovomies/media/20140717_134015_zpsbd6d84fa.jpg.html)
purkurien ja takavalojen kaupat sovittu.
valoiksi tulee uusimmat("lovettomat") kirkkaalla vilkulla.
takapuskuri tulee 960:stä.
etupuskuri orkkis pikku lisäyksellä.
vanteita ajattelin kans päivittää ja tämmöset ois tulossa jos hinnasta päästään yhteis ymmärrykseen.
(http://www.myfto.co.uk/media/images/spyder2.jpg)
960 muovi helmat ja roiskeläpät tarvii vielä ja niitä voi tarjota yv:n
puskurit ja taka valot tuli eilen ja sovitin niitä paikalleen, kaikki passa kuin nenä päähän.
ilta taas auton kimpussa ja pintamaalia vaille lähetään huomenna alastaroon.
perus huolto meni enemmän kuin vituralleen. pientä nykimistä ollut ja sitä ollaan selvitelty jo ennen kolaria.
uus bensapumppu on laitettu, bp säädin uus, kampuran anturi uus, bp paineet mitattu ja ovat ok.
nyt sitte ei lähtenyt hallin pihalta käyntiin. räknättiin aikamme ja mitattiin jännitteitä vähä joka paikasta.
kaikki piti olla ok. sulakkeet kateltiin jne. sitte lähti yhtäkkiä käyntiin ja ajettiin halliin sisälle pika kasausta ja perus huoltoa varten.
ite kasailin takapäätä autosta ja kaveri vaihtoi uudet sytytys osat= virranjakajankansi, pyöriä, tulpanjohdot sekä tulpat.
toiveissa tällä operaatiolla oli saada nykiminen pois.
mutta voihan silimä ku ei keksintö lähde käyntiin ei sitte millään.
irtotulpalla tuli kipinä mutta ei käy vaikka putken päässä haisi bensa. raavittiin päätä ja penaalia kilpaa ja lopen mitattiin tulpanjohdot, puolanjohto, pyöriä, virranjakajankansi. kaikki oli kunnossa. virran jakajan kannet uus ja vanha tarkkaan syyniin ja uudessa oli keskihiili huomattavasti syvemmällä kuin vanhassa ja siinä oli ohmi mittauksen perusteella kehnopi tulos kuin vanhassa. sama mittaus osoitti vanhan pyöriän olevan huomattavasti parempi kuin uusi.
vanha kansi ja pyöri paikalleen ja auto käyntiin...
jäi sitte puskurien laitto huomiselle...
että tämmönen ilta.
Kestikö se klemmari + purkkapatentti bensaletkussa kotiin asti? ???
kesti perille. eihän tuota matkaakaan ollu kotiin kuin 580km.
renkaatkin kesti perille asti.
melko pienillä murheilla sai reissun tehtyä vaikka radalla sai auto kohtuu kyytiä...
Hyvä hyvä. O0 Täytyykin ottaa varmuudeksi seuraavalle reissulle pussillinen klemmareita mukaan. :juhau:
Ja enemmän kaljaa :2funny:
ei sillä kierrosajat parene eikä auto kestä sen paremmin...
Nyt on ahtoja nostettu ja bp painetta myös. Pennin viritykset tehtynä.
Renkaat uusittu, samalla alle tuli 16"hydrat.
lievä makitan alustasarja laitettiin paikalleen.
Nyt ouluzoneen kokeileen auttoko räpeltämiset mitään.
kevyt madallus. ja laiska avainpoika.
(http://i1051.photobucket.com/albums/s422/volovomies/20140809_025630_zps33e951ca.jpg) (http://s1051.photobucket.com/user/volovomies/media/20140809_025630_zps33e951ca.jpg.html)
eilen käytiin radalla sulattaan renkaita. kaverilla karkasi perä alta.
(http://i1051.photobucket.com/albums/s422/volovomies/20140809_160952_zps7ca0e496.jpg) (http://s1051.photobucket.com/user/volovomies/media/20140809_160952_zps7ca0e496.jpg.html)
https://docs.google.com/file/d/0B7q5Kr3CyezzSmVPa1IxN0J1SGM/edit?pli=1
rata ajelua
kallistelu kuvia...
(http://i17.photobucket.com/albums/b87/SlowmanFin/Vrcf%202014/P1220612_zps257b4d33.jpg) (http://s17.photobucket.com/user/SlowmanFin/media/Vrcf%202014/P1220612_zps257b4d33.jpg.html)
(http://i17.photobucket.com/albums/b87/SlowmanFin/Vrcf%202014/P1220622_zps17ac3ce3.jpg) (http://s17.photobucket.com/user/SlowmanFin/media/Vrcf%202014/P1220622_zps17ac3ce3.jpg.html)
(http://i17.photobucket.com/albums/b87/SlowmanFin/Vrcf%202014/P1220623_zps42ce6633.jpg) (http://s17.photobucket.com/user/SlowmanFin/media/Vrcf%202014/P1220623_zps42ce6633.jpg.html)
