2.4D V70 2007 vikakoodit ja punainen kolmio ?
  • 5 Vastauksia
  • 6360 Lukukerrat
Xenonit
« : 04.07.2012, 22:21:06 »
Mäen päällä syttyi punainen varoituskolmio ja vikakoodit luettua antoi auto seuraavat viat:
P2A00 & P2015.
Mitä meinaavat ?
Poissa kaksi70
  • Volvo V70 2010 2,0D Momentum
Vs: 2.4D V70 2007 vikakoodit ja punainen kolmio ?
« Vastaus #1 : 04.07.2012, 22:39:24 »
Jotain löytyi googlaamalla, vähän haasteellista tulkita
Generic OBD Error Code Details for P2A00
O2 Sensor Circuit Range/Performance
Generic OBD Error Code Details for P2015
Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance
P2015 - Generic Type Powertrain - Fuel and Air Metering and Auxiliary Emission Controls - ISO/SAE Controlled
Description Intake Manifold Runner Position Sensor/Switch Circuit Range/Performance
Location Bank 1
Notes DTC Application note for Intake Manifold Tuning Valves and Intake Manifold Runner controls: Active controls are used to modify or control airflow within the engine air intake system. These controls may be used to enhance or modify in-cylinder airflow motion (charge motion), modify the airflow dynamics (manifold tuning) within the intake manifold or both. Devices that control charge motion are commonly called Intake Manifold Runner Control, Swirl Control Valve, and Charge Motion Control Valve. The ISO/SAE recommended term for any device that controls charge motion is Intake Manifold Runner Control (IMRC). Devices that control manifold dynamics or manifold tuning are commonly called Intake Manifold Tuning Valve, Long/Short Runner Control and Intake Manifold Communication Control. The SAE recommended term for any device that controls manifold tuning is Intake Manifold Tuning (IMT) Valve.
Nyt : V70 -10 2,0D Momentum, Ex:740 -89 B200F aut, V70 -07 Classic 2,4D Geartronic, V70 -01 2,4 , S70 -99 2,5 20 V, V70 -09 D5 Summum Geartronic, V70 -01 2,4T aut
Xenonit
« Vastaus #2 : 04.07.2012, 23:28:31 »
Vielä kun joku kääntäisi ;)
Xenonit
« Vastaus #3 : 13.07.2012, 06:38:22 »
Osaako kukaan suomentaa/tulkita mistä vika voisi löytyä ?
Poissa V70 D5-07
« Vastaus #4 : 15.07.2012, 18:10:09 »
Generic OBD Virhekoodi Tiedot P2A00 O2 Sensor Circuit Range / Performance Generic OBD Virhekoodi Tiedot P2015 Imusarjan Runner Position Sensor / Switch Circuit Range / Performance P2015 - Generic Tyyppi Voimansiirto - polttoaineen ja ilman mittaus ja Auxiliary Päästöjen - ISO / SAE Controlled Kuvaus Imusarjan Runner Position Sensor / Switch Circuit Range / Performance   Paikka Pankki 1 Huomautuksia DTC Application note Imusarjan Tuning Venttiilit ja imuilman Juoksija valvonta: Aktiiviset valvontaa käytetään muokkaamaan tai hallita ilmavirran sisällä moottorin ilmanotto järjestelmä. Näitä tarkastuksia voidaan parantaa tai muuttaa in-sylinterin ilmavirran liikkeen (lataus liikettä), muuttaa ilmavirran dynamiikka (imusarjan viritys) sisällä imusarjaan tai molempia. Laitteet, ohjaus maksu liikettä kutsutaan yleisesti Imusarjan Runner ohjaus, Swirl Control Valve, and Charge Motion Control Valve. ISO / SAE suositeltava termi tahansa laite, joka ohjaa maksu liike on Imusarjan Runner Control (IMRC). Laitteet, jotka säätelevät imusarjan dynamiikka tai imusarjan viritys kutsutaan yleisesti Imusarjan Tuning Valve, long / short Runner ohjaus ja imuilman tiedonvälityksen valvonta. SAE suositeltava termi tahansa laite, joka ohjaa imusarjan viritys on Imusarjan Tuning (IMT) Valve.
Tommonen tuli tulkilla vapaasti Suomennettuna,en tiedä auttako sinua ongelman suhteen ;)
Edelliset:2Xv40 ja S60 D5 Aut.V70 D5 Aut.
Nyt: Cooper-66,Can-am outlander 650 abs-18.Volvo V60 D4 AWD-20.Valmet 604-83.Valmet 361D-62
Poissa Jorma
« Vastaus #5 : 15.07.2012, 18:24:06 »
Pitäs varmaan lukea koodit jollakin toisellakin laitteella. Nuo selitykset, vieläpä käännettynä, ei paljon taida auttaa. Lukeekohan PPC-1 tuota mallia vielä, lukee kyllä vm 2007, joten mahdollisuuksia on. Jossain oli lista, mistä näki missäpäin lukijoita löytyy. Itsellä on Vihdissä.
