AW7x kiristysmomentit
  • 0 Vastauksia
  • 2926 Lukukerrat
Poissa sekokupu
  • Volvo Rapist Club Finland
« : 07.09.2014, 17:55:10 »
Laatikon leväyttäjälle hyödyllistä tietoa.
Pultti/mutteri:                                                   Kiristysmomentti (Nm)
Torque converter housing - engine, M 10           35-50
M 12        55-90
Drive plate - torque converter                           41-50
Centre support - gearbox housing:
Tighten alternately in steps of 7 Nm (5 ft.lb)       24-28
Pump body - pump cover                                   6-9
Pump - gearbox housing                                    22-28
Parking pawl, locking plate                                  6-9
Torque converter housing - gearbox housing
4 x M 10                                                            27-42
2 x M 12                                                            48-68
Rear extension housing - gearbox housing            27-47
Valve body, for cam, M 6                                    6-9
other bolts, M 5                                                  5-6
Strainer - lower valve body                                  5-6
Cover plate - gearbox housing (governor), M 6    6-9
Control system - gearbox housing                        8-12
Oil sump - gearbox housing                                  4-5
Coupling flange - output shaft*                            40-50
Plug, pressure gauge tapping                                5-9
Oil cooler connections - gearbox housing              20-30
Speedometer drive, mounting                               4-6
Nut, fluid filler tube                                                80-90
Solenoid valve                                                      10-16
Drain plug, oil sump                                              18-23
