Volvo B230ft, wiseco, 16v, m90, multilink and so on for sale (SOLD)
  • 0 Vastauksia
  • 3967 Lukukerrat
Poissa naxitrall
Hi everyone,
I have some interesting parts for sale if anyone interested.
*B230ft engine block witch is already bored to 1st oversize with stress plate. (It comes with everything, etc. oil sump/pump, waterpump and so on)
*16V full cylinder head with cams, intake and everything. Head has valve radius seats done and minimal porting job + Double valve springs
*16V stock camshaft sprockets witch has CNC job done and made adjustable inserts in.
*B230 wiseco pistons 1st oversize for 16v upgrade (new, in box)
*B230 H rods with ARP bolts (new, in box)
*Siemens deka 107961 630cc injectors x4 (used max 200km)
*Cylinder head ARP studs for 16v conversion (new, in box)
*B230 cranckshaft STD. size. Measured and polished.
*Master power R-474 with internal wastegate (new, never used)
*Sachs Race Engineering 883082999763 Clutch pressureplate (used max 1000km)
*Sachs Race Engineering 881864999993 Clutch disk with 4 pads (used max 1000km)
*Redblock M90 transmission fully working and in very good condition, no syncro problems. (comes with all parts needed for conversion etc. driveshaft witch has new crosses and center support, garbox beam, slave cylinder and so on.)
*Multilink II from volvo 960 with differential lock inside. (all brackets, bolts, brake cylinders and all)
I dont have pictures from everything but if needed i can make them.
Some are here:
All these parts are located in Estonia, Tallinn. I can send by DPD, deliver personally to Helsinki for some money or you can come to Tallinn.
Price for everything is 2500€ what i dont want to lower  ::)
You can SMS me +372 555 32 810 or send private message. I speak only in English or Estonian :)
« Viimeksi muokattu: 06.05.2016, 03:13:47 kirjoittanut naxitrall »
