Autovideokamerat topicci
  • 860 Vastauksia
  • 373644 Lukukerrat
Poissa Rompe
  • V70 2,4D -07 Classic, Busines, Cromiumpack
Vs: Autovideokamerat topicci
« Vastaus #345 : 25.08.2013, 10:28:11 »
Kysymys: Saatko kameran näytölle nopeuden? Kertoo nopeasti onko gps:ää vai ei.
Ei saa
Poissa -karppa-
  • Valoisin ajatuksin
  • Keski-ikäinen jeesustelija
« Vastaus #346 : 25.08.2013, 11:10:40 »
Ei saa
Kiitos. Eli nyt todistetusti Mikan on väärässä  ;) eikä tuo ole sama malli mikä itsellä eikä siinä ole tuota sisäänrakennettu gps:ää mihin hain vastausta.
Poissa mikan
  • Hostellitonttu
« Vastaus #347 : 25.08.2013, 14:16:29 »
Perkeles!   >:(
Kiinan pojat ovat sitten jotain välpänneet koska tuon Sku numeron ne minulle antoivat kun nimenomaisesti sitä kysyin.
Hintakin on tippunut aikas kiitettävää tahtia, mutta jotain on tapahtunut koska kyseisen mallin asiakas kommenteissa mainitaan mm. näin.
Lainaus
posted by V8Rocks on 20:19:27 G5T 18/05/2013 certificated customer
Involvement Level: Expert (understands the inner workings)
Pros: FW v.4.36.xxx. Quick GPS signal acquisition. Everything works right, no glitches. Easy to upgrade to HD50G_v436.030912 or HD50G_130515 firmware that make it even better, especially GPS time sync. Wealth of options to configure it the exactly the way you want it.
Cons: None so far. No mph, only kmh for speed
Other: Would recommend. Good value and quality. Shipping was relatively quick.
Original iTracker GS1000 Dash cam
posted by nikb on 07:11:39 G2T 21/02/2013 certificated customer
Pros: It is an original Orange Menu GS1000 dash cam from iTracker with firmware SMH4.36.220812B It is with GPS that pick up satellite and G-sensor that it works It can record in HD (1920x1080) with great quality Cycle record works fine. Works with High Speed microSD cards Comes with a CD with the required codec’s.
Cons: The recorded sound is poor. The night recording is very poor. It increases temperature after a one hour of continuous recording. The battery is not removable.
Other: Exactly as expected to be. Highly recommended!!!
Ja niin edes päin....
Ja se sopii siihen mitä olen itse havainnut!
Petosta! Pirskatti soikoon!  :peetu:
Ei saa
Kirjoittaako se sinun versiosi sinne muistikortille videosoittimen omaan kansioonsa kun laitat tyhjä kortin kameraan?
Mikä on sen firmis-numero ja näyttääkö sen menut ja starttikuva tälle?
Ruumiinavauksesta kuvia:
http://www.vrcf.fi/foorumi/index.php?topic=14954.msg561152#msg561152
Mutta jos hakee jotakin samaa satsia, niin tässäpä on DOD TG300:
http://dx.com/p/dod-tg300-hd-1080p-1-5-tft-wide-angle-night-vision-car-dvr-w-mini-hdmi-8x-digital-zoom-black-207288
Maksaa sen satkun mutta pitäisi olla aikais messevää kuvanlaatua, jopa hämärässäkin.
Mutta hintaa taas se rapia satku.  Joten hyvä ja halpa edellyttää kahden ostamista!
Häkä piristää!
Poissa Rompe
« Vastaus #348 : 25.08.2013, 14:59:19 »
Sinisellä valikolla. Ja avausnäytössä ei tekstiä. Siinä on joku autonkuva.
Täytyy katsoa tyhjällä kortilla mitä tekee...
Ruumiinavaus näytti melko samalta. Jopa siihen jalkaan meni johto. En kylläkään antennia kaivanut esille...
Poissa mikan
  • Hostellitonttu
« Vastaus #349 : 25.08.2013, 15:44:04 »
Lukiko siellä prosarissa ambrella vaiko novatek?
Häkä piristää!
Poissa mikan
  • Hostellitonttu
« Vastaus #350 : 25.08.2013, 16:21:05 »
Onko sen perusnäkymä tälläinen?
http://aijaa.com/whVpiq
Eli näkyykö siellä vasemmassa alakulmassa satelliittilautanen sen muistikortin kuvan yläpuolella?
Häkä piristää!
Poissa Rompe
« Vastaus #351 : 25.08.2013, 17:23:08 »
Ambarella
Ei taida. Menen kohta autolle niin näen. Pitää otta kuva "todisteeksi"
« Vastaus #352 : 25.08.2013, 17:44:20 »
jahka mun tilaama käsittääkseni sama sku tulee niin jännä nähdä onko sitä gps:ää, en sinäänsä sitä tarvitse mutta jos sku ei vaihdu kun tuote vaihtuu se kyllä on paha juttu se
Poissa Rompe
« Vastaus #353 : 25.08.2013, 19:47:36 »
Avauskuva
Valikko ja softaversio
Poissa Rompe
« Vastaus #354 : 25.08.2013, 20:04:39 »
Toi on ihan saman näköinen kun mulla on , ja GPS toimii ok
Jos siinä olisi GPS, niin valikosta varmaan pitäisi löytyä asetus sille? Edes siinä missä valitaan mitä kuvassa näkyy...
Poissa mikan
  • Hostellitonttu
« Vastaus #355 : 26.08.2013, 22:45:14 »
Hm....  Se ei ole sama kamera kuin minulla, sillä sen pitäisi olla oranssi-menuinen.
Mitä sinulla voi valita siinä kuvassa näkyvissä valinnoissa?
Häkä piristää!
Poissa Rompe
« Vastaus #356 : 27.08.2013, 05:37:44 »
Shock On-off
G sensor 1-8
Stamp Off-Time-Time/date
Kieli
Muistikortin alustus ja millä tavalla tiedostot nimetään
Toisessa valikossa oli ne kuva ja ääni valinnat
Poissa Rompe
« Vastaus #357 : 27.08.2013, 05:44:34 »
Piti viellä tarkistaa tuo DXän koodi SKU: 118263
Mutta samahan se on kun linkissäsi kun siitä mä sen tilasinkin.
Poissa -karppa-
« Vastaus #358 : 27.08.2013, 06:32:22 »
Mullakaan ei mitään autoa tule alussa ja valikko on oranssi, niin kuin Mikan:lla.
s73
« Vastaus #359 : 05.09.2013, 18:38:28 »
Fixuksella näkyy olevan myynnissä paria kameraa,  tekeekö niillä mitään? ???
