Ahtimen öljynpaluu
  • 61 Vastauksia
  • 51604 Lukukerrat
Poissa puliukk0
Vs: Ahtimen öljynpaluu
« Vastaus #15 : 30.05.2013, 22:57:17 »
Muistelisin, että 25mm siitä mihin putki tiivistyy ja itse reikä taisi olla 16mm
Itse teetin siihen lohkoon semmoisen "billet"osan jonka naputtelin varovasti lukkoliiman kera pohjaan.
Ei ole vuotanut, kuvankin voin tähän kohta laittaa niin ymmärrätte mistä höpisen.
Tälle ois kova kiinnostus + mitä mahtaisi maksaa :)
-Toyota Prius -04 "Ekopönttö"
Poissa reve
« Vastaus #16 : 31.05.2013, 09:21:32 »
Holsetin tehdasmanuaalista:
Lainaus
Installation Data
1.   Mount the turbocharger on the turbine inlet flange. All other connections must be flexible and heavy pipework
should be supported. Always pre-lube with clean engine oil.
2.   Always position the bearing housing so that the oil drain is at the bottom and kept within 22˚ of the vertical centre
line when installed on the engine.
3.   Oil should be filtered below 15/20 microns. The oil quality must be as specified by the engine manufacturer.
e.g. API - CD (MIL - L - 2104C). Improvement in life can be obtained by using super high performance diesel
(SPHD) oils, particularly where extended oil drain periods are used.
4.   Oil pressure must show at the turbocharger oil inlet within 3 - 4 seconds of engine firing to prevent damage to
turbocharger bearing system from lack of lubrication.
5.   The minimum oil pressure, when the engine is on load must be 210 kPa [2.0 kgf/cm 2 , 30 lbf/in 2 ] and pressures up
to 415 kPa [4.0 kgf/cm 2 , 60 lb/in 2 ] are satisfactory. Under idling conditions the pressure should not fall below 70 kPa
[0.7 kgf/cm 2 . 10lbf/in 2 ].
6.   The oil inlet pipe should be 9.5 mm [0.375 in.] bore minimum and the oil drain pipe should be 19 mm [0.75 in.] bore
minimum. The oil must drain downwards by gravity from the turbocharger into the engine under all operating
conditions.
7.   Air cleaner pressure drop should not exceed 500 mm [20 in.] of water. Avoid damp/wet air conditions in filter as this
can dramatically increase pressure drop on a temporary basis.
8.   The exhaust back pressure after the turbocharger should not exceed 500 mm [20 in.] of water. Consult Holset
where high restrictions are expected, particularly when exhaust brakes are to be used.
Poissa ässäarpa
  • -Team Karvavako Racing-
« Vastaus #17 : 03.06.2013, 17:03:03 »
Pari paskaa puhelin kuvaa.
Kaveri tuon koneistamolla mulle tekas rosteriputkesta.
Taisi maksaa n. 6e.
Tuohon voisi tehdä semmoisen olakkeen jonka takana letku kestäisi klemmarin kanssa paremmin.
« Viimeksi muokattu: 03.06.2013, 17:09:58 kirjoittanut ässäarpa »
144
145
945
855
Poissa ässäarpa
« Vastaus #18 : 04.06.2013, 17:35:07 »
Pari kyselyä tuli yvllä mulle noista nipoista, onko kellään muulla halukkuutta tommoselle, jos teettäisin pienen satsin noita?
Väärä paikka varmaan kysellä mutta menköö nyt.
144
145
945
855
Poissa AnttiR
« Vastaus #19 : 04.06.2013, 20:25:18 »
Minulle yksi kappale!
-Volvo 850 T-5R -95
-Volvo 242 -81
Poissa Sato|
« Vastaus #20 : 05.06.2013, 13:28:44 »
Mullekkin kelpais jos vielä mukaan ehtii  :hello:
« Vastaus #21 : 06.06.2013, 21:20:17 »
Mulle kans yksi tollanen natsa kiitos.
« Vastaus #22 : 07.06.2013, 13:53:58 »
Jos ne jotain kuuden eekkerin tienoilla on hinnaltaan, niin miksei tännekkin?  :hello:
Poissa ässäarpa
« Vastaus #23 : 07.06.2013, 14:06:43 »
En tiedä tarkkaa hintaa vielä, mutta epäilen että hinta tuosta vielä vähän nousee.
144
145
945
855
Poissa järviin
« Vastaus #24 : 07.06.2013, 19:11:28 »
Jos päästään yli 12€, niin voisin ottaa yhden.
Poissa ässäarpa
« Vastaus #25 : 08.06.2013, 00:21:46 »
Eli alle 12e hintaan ei kelpaa?  :buck2:
 :D :D
144
145
945
855
« Vastaus #26 : 08.06.2013, 01:13:35 »
oma versio:
Ensin kierteet lohkoon alkuperäiseen reikään. Sitten siihen sopiva muhvi kierrelukitteella ja alkuperäisellä tiivisteellä paikoilleen.
Tää meni paikoilleen hiukan muokattuna. ;)
Sitten vaan liitin ja letkua kiinni
yläpää kans toteutettu an-liittimellä.
« Viimeksi muokattu: 08.06.2013, 01:15:49 kirjoittanut Rusakko »
Poissa ässäarpa
« Vastaus #27 : 08.06.2013, 02:10:54 »
Toi onkin hyvä, mutta edellyttää öljypohjan poistoa, jotta lastut saa pois öljykierrosta.  :)
144
145
945
855
« Vastaus #28 : 08.06.2013, 07:09:51 »
Paljonko on sisähalkaisija tuosta mutkan kohdalta?
oma versio:
(Kuva poistettu lainauksesta.) (Kuva poistettu lainauksesta.)
« Vastaus #29 : 08.06.2013, 10:50:43 »
empä oo mittaillu. Ei eroa paljoa letkun sisähalkaisijasta.
