Valmistenumerosta selville vuosimalli ?
  • 14 Vastauksia
  • 30840 Lukukerrat
Xenonit
« : 14.12.2011, 22:00:59 »
Onko autoni todellakin 2008 ja kertooko sen kymmenes merkki ?
YV1SW694082690170
Poissa Puusilmä
  • Kankea kahvimestari sr.
Vs: Valmistenumerosta selville vuosimalli ?
« Vastaus #1 : 14.12.2011, 22:08:04 »
Poissa Pyssy
  • :p
    • Oldsmobile Club of Finland ry.
« Vastaus #2 : 15.12.2011, 01:52:42 »
Näin se menee:
VIN-koodi
Sallitut merkit:
ABCDEFGHJKLMNOPRSTUVWXYZ123456789
Latinan aakkoset, joista puuttuu I ja Q.  Nolla tulkitaan yhdeksättä merkkiä laskettaessa O-kirjaimeksi
1,2 valmistusmaa
Africa A - H
AA-AH South Africa
AJ-AN Ivory Coast
AP-A0 not assigned
BA-BE Angola
BF-BK Kenya
BL-BR Tanzania
BS-B0 not assigned
CA-CE Benin
CF-CK Malagasy
CL-CR Tunisia
CS-C0 not assigned
DA-DE Egypt
DF-DK Morocco
DL-DR Zambia
DS-D0 not assigned
EA-EE Ethiopia
EF-EK Mozambique
EL-E0 not assigned
FA-FE Ghana
FF-FK Nigeria
FF-FK Madagascar
FL-F0 not assigned
GA-G0 not assigned
HA-H0 not assigned
 Asia J - R
JA-J0 Japan
KA-KE Sri Lanka
KF-KK Israel
KL-KR Korea (South)
KS-K0 not assigned
LA-L0 China
MA-ME India
MF-MK Indonesia
ML-MR Thailand
MS-M0 not assigned
NF-NK Pakistan
NL-NR Turkey
NS-N0 not assigned
PA-PE Philipines
PF-PK Singapore
PL-PR Malaysia
PS-P0 not assigned
RA-RE United Arab Emirates
RF-RK Taiwan
RL-RR Vietnam
RS-R0 not assigned
 Europe S - Z
SA-SM Great Britain
SN-ST Germany
SU-SZ Poland
S1-S0 not assigned
TA-TH Switzerland
TJ-TP Czechoslovakia
TR-TV Hungary
TW-T1 Portugal
T2-T0 not assigned
UA-UG not assigned
UH-UM Denmark
UN-UT Ireland
UU-UZ Romania
U1-U4 not assigned
U5-U7 Slovakia
U8-U0 not assigned
VA-VE Austria
VF-VR France
VS-VW Spain
VX-V2 Yugoslavia
V3-V5 Croatia
V6-V0 Estonia
WA-W0 Germany
XA-XE Bulgaria
XF-XK Greece
XL-XR Netherlands
XS-XW U.S.S.R.
XX-X2 Luxembourg
X3-X0 Russia
YA-YE Belgium
YF-YK Finland
YL-YR Malta
YS-YW Sweden
YX-Y2 Norway
Y3-Y5 Belarus
Y6-Y0 Ukraine
ZA-ZR Italy
ZS-ZW not assigned
ZX-Z2 Slovenia
Z3-Z5 Lithuania
Z6-Z0 not assigned
 North America 1 - 5
1A-10 United States
2A-20 Canada
3A-3W Mexico
3X-37 Costa Rica
38-30 not assigned
4A-40 United States
5A-50 United States
Oceania 6 - 7
6A-6W Australia
6X-60 not assigned
7A-7E New Zealand
7F-70 not assigned
South America 8 - 9
8A-8E Argentina
8F-8K Chile
8L-8R Ecuador
8S-8W Peru
8X-82 Venezuela
83-80 not assigned
9A-9E Brazil
9F-9K Colombia
9L-9R Paraguay
9S-9W Uruguay
9X-92 Trinidad & Tobago
93-99 Brazil
90 not assigned
2. valmistaja
3. merkki
4-8. malli
9. tarkistusnumero
Check Digit Information
To determine check digit (9th digit) of your car you need to take the VIN and assign any letters in the VIN with a set value (number) as follows
  A = 1, B = 2, C = 3, D = 4, E = 5, F = 6, G = 7, H = 8,
  J = 1, K = 2, L = 3, M = 4, N = 5, O = 6, P = 7, R = 9,
  S = 2, T = 3, U = 4, V = 5, W = 6, X = 7, Y = 8, Z = 9
Any numbers in the VIN remain the same (not replaced) and thus you have a 17 digit number.
Then you must multiply each of the 17 digits by a set "weight" (multiplier). The weight applied to each digit is as follows
  1st = 8, 2nd = 7, 3rd = 6, 4th = 5, 5th = 4, 6th = 3, 7th = 2, 8th = 10,
  9th = 0 (check digit), 10th = 9, 11th = 8, 12th = 7, 13th = 6, 14th = 5,
  15th = 4, 16th = 3, 17th = 2
The products are all added together and divided by 11.  The remainder is the check digit.  If the remainder is 10 then the check digit is X
10. valmistusvuosi
A   1980   2010   2040
B   1981   2011   2041
C   1982   2012   2042
D   1983   2013   2043
E   1984   2014   2044
F   1985   2015   2045
G   1986   2016   2046
H   1987   2017   2047
J   1988   2018   2048
K   1989   2019   2049
L   1990   2020   2050
M   1991   2021   2051
N   1992   2022   2052
P   1993   2023   2053
R   1994   2024   2054
S   1995   2025   2055
T   1996   2026   2056
V   1997   2027   2057
W   1998   2028   2058
X   1999   2029   2059
Y   2000   2030   2060
1   2001   2031   2061
2   2002   2032   2062
3   2003   2033   2063
4   2004   2034   2064
5   2005   2035   2065
6   2006   2036   2066
7   2007   2037   2067
8   2008   2038   2068
9   2009   2039   2069
11 Tehdas
12-14 Valmistajakohtainen koodi (alle 500 ajoneuvoa vuodessa)
12-14 Sarjanumeron alku (yli 500 ajoneuvoa vuodessa)
12/15-17 Sarjanumero(n loppuosa)
Etuvetoiset ei ole Volvoja
Nelitahtiset ei ole Saabeja
Vesijäähdytteiset ei ole Porscheja
Alle 11-sylinteriset ei ole Ferrareja
Poissa Ristus
    • Kotisivut
« Vastaus #3 : 15.12.2011, 12:59:00 »
yks lisää http://www.motoverse.com/tools/vinDecoder.asp ja on 2008 swedu volvo
YouTube
Xenonit
« Vastaus #4 : 17.12.2011, 11:09:55 »
Tehdäänkö noita jossain muualla kuin sweduissa eli voisiko alla huonolla tuurilla olla puolalainen v70 ?
Poissa Taavi.H
« Vastaus #5 : 17.12.2011, 14:20:07 »
Belgiassa on iso osa Volvoista tehty, taitaa sieltä tulla enemmän Volvoja kuin Ruotsista. S60 ja V70 lienee pääosin tehty siellä.
V60 D6 PHEV -14
Poissa revote
  • "epätietoinen"
« Vastaus #6 : 17.12.2011, 14:25:07 »
Onko tötterö tehnyt kerrankin huonot autokaupat ;)
Blacked S60 Instagramissa
Poissa sjs
« Vastaus #7 : 19.12.2011, 23:08:20 »
Sehän noissa valmistenumeroissa kannattaa huomioida että ne eivät aina kerro valmistusmaata.
Esim. Volvo S/V40 alkaa YV1, mutta valmistettu belgiassa, moni isompi volvo sama homma. MB Vito alkaa WDB638 tai WDB639, mutta ne ovat valmistettu Espanjan Vitoriassa. Citroen Jumper, Peugeot Boxer alkavat VF3 ja VF7 jos en muista väärin, ja ne valmistetaan Italiassa fiat:in tehtaalla. Muistaakseni Fiat Ducato:kin alkaa VF2.
Sitten jostain syystä 300/400 sarjan volvot on valmistettu hollannissa ja niiden alustat alkavat XLB.
Lähes kaikkien autojen mallikyltissä (5x8cm alumiinilätkä jossa lukee alustanumero, EY-tyyppihyväksyntäkoodi, akselimassat, moottorin malli+sarjanumero (ei aina) ja tietoja maalipinnasta ja sisustasta + alustasta) lukee valmistusmaa. Näin ainakin kaikissa volvoissa joita minulle tullut vastaan.
Poissa Pyssy
  • :p
« Vastaus #8 : 22.12.2011, 01:14:17 »
Valmistusmaa on nykyään vaikea määritellä, kun puolivalmisteita kuljetetaan pitkin Eurooppaa tehtaasta toiseen.  Ajoneuvon VINniä, ja kauppatavaran "Made in"-merkintää sitovissa määräyksissä on eroja, koska ne on sovittu eri aikoihin eri konferensseissa.
Jos valmistusmaa on koodattu valmistenumeroon väärin, on se vähintään sopimusrikkomus, ellei peräti petos.  Ei siihen kukaan vakavasti otettava valmistaja ryhdy.  Ja minusta se on ihan sama, onko jonkin Mersun tehneet turkkilaiset Saksassa vai marokkolaiset Espanjassa.
300-sarja ei suunnitteluvaiheessa vielä ollut Volvo, vaan siitä piti tulla DAF 77.  Volvo osti van Doornes Automobielfabriek'in henkilöautopuolen.  Kaikki 300-sarjalaiset tehtiin Alankomaissa, siitä maakoodi XL, joka mahtuu Alankomaille määritellylle välille XL...XR.  Pikaisen Wikipedian selaamisen perusteella ei 300- ja 400- sarjaa ole ikinä tehty muualla kuin Alankomaissa eli "Hollannissa".
Romeo
« Vastaus #9 : 04.03.2012, 19:29:51 »
Edit offtopic
« Viimeksi muokattu: 04.03.2012, 19:32:41 kirjoittanut Romeo »
Poissa vee-seitkyt
« Vastaus #10 : 14.11.2015, 22:54:19 »
OK, eli vuosimallia ei siis näe valmistenumerosta, ainoastaan valmistusvuoden. Asiasta on tosin näemmä ristiriitaista tietoa tälläkin palstalla ("Puusilmä":n vastauksen linkissä väitetään toisin).
Näin se menee:
VIN-koodi
10. valmistusvuosi
A   1980   2010   2040
B   1981   2011   2041
C   1982   2012   2042
D   1983   2013   2043
E   1984   2014   2044
F   1985   2015   2045
G   1986   2016   2046
H   1987   2017   2047
J   1988   2018   2048
K   1989   2019   2049
L   1990   2020   2050
M   1991   2021   2051
N   1992   2022   2052
P   1993   2023   2053
R   1994   2024   2054
S   1995   2025   2055
T   1996   2026   2056
V   1997   2027   2057
W   1998   2028   2058
X   1999   2029   2059
Y   2000   2030   2060
1   2001   2031   2061
2   2002   2032   2062
3   2003   2033   2063
4   2004   2034   2064
5   2005   2035   2065
6   2006   2036   2066
7   2007   2037   2067
8   2008   2038   2068
9   2009   2039   2069
Poissa Taavi.H
« Vastaus #11 : 14.11.2015, 23:04:34 »
Ei kun juuri päinvastoin. Vuosimallin se 10. merkki kertoo.
V60 D6 PHEV -14
Poissa (Miksu)
  • www.carcom.fi
« Vastaus #12 : 14.11.2015, 23:34:51 »
Jeeh  ja se on nimenomaan mallivuosi, eli tällähetkellä myytävät on jo merkinnällä F, mallivuosi 2016
Elikkäs 2010 malli on sit taas A, 2011 on B  jne.
Poissa eehoo
  • Volvo XC60 T6 AWD
« Vastaus #13 : 18.06.2025, 10:30:07 »
Miten mulla on B eli 2011 ja auton kojelauta, mittarit, keskikonsoli, tekniikka jne on 2012 mallisen. Ostettu USA:sta uutena. Rekisteröity vuoden lopussa ja on alkuperäinen, eli ei rakennettu.
Volvo XC60 T6 AWD
Poissa JJJ
« Vastaus #14 : 18.06.2025, 16:05:20 »
Ne Volvollakin laittaa autoon kiinni vähän mitä sattuu jos ollaan mallivuosien rajamailla.
Mulla oli MY20 jonka sain heinäkuussa -19, siinä oli osa varusteista 19 ja osa 20 listalta.
